hi there!
what is diffrent between Hotspot DHCP and the IP>DHCP Server ?
when you are setting up hotspot on one of the router interface(E.g. Ether 2) while it has already been a dhcp server, so why you need to use dhcp config during hotspot setup ?
(hotspot on Ether2, by the way)
and i tried it and saw that before a client log on hotspot, it already takes IP from DHCP. and after i log in hotspot no changes in IP address accured .(even after disabling and enabling the client NIC)
config on mikrotik :
IP> DHCP Server on Ether 2 : 172.16.10.100-172.16.10.200
hotspot DHCP CONFIG on Ether2 : 172.16.10.50-172.16.10.90
could you please explain the difference between these two dhcp ?
