i tried to configure my wireless network. i have 2 wireless networks but 1 wireless AP(RB500) . I then wanted to try out hotspot on 1 of the networks so i applied hotspot to the wlan interface but to the address pool of the second network expecting that this will not affect the first wireless network, but whne i tested it i realised it affected both networks and even system with static ip’s from the other subnet are transfered to this network by the one - one NAT. please is there a way i can prevent the 2 networks from jumping into each other ie can i stop the hotspot server from NATing the first network.
You should put hotspot and regular network on different interface.
Or for regular user, you can try PPPoE.
User can choose if they want to login through hotspot or PPPoE.
Try to run hotspot only in the interface that you need hotspot access…
And to not disturb with NAT 1-1 select “None” in Address Pool of Hotspot Server ![]()
Regards!
Alessio
thank you very much
