Hello friends. I have a router that has multiple networks and the router has a roll for dns. I have a problem with the hotspot, and can not intercept and redirect the different dns server addresses manually seted from clients. The standard rule can not intercept addresses from hotspots network only.
My question is with which rule put in the firewall to redirect to the local router addresses at a hotspot too?
I can only show you what I do…
set allow-remote-requests=yes servers=\
8.8.8.8,8.8.4.4,208.67.220.220,208.67.222.222
add address=192.168.0.0/24 comment=HomeDHCP dns-server=192.168.0.1 gateway=\
192.168.0.1
add address=192.168.2.0/24 comment=DMZLan_Network dns-server=192.168.2.1 \
gateway=192.168.2.1
/ip firewall filter (I only allow certain traffic and use drop rule at end of chains)
{input chain}
add action=accept chain=input comment="Allow LAN DNS queries-UDP" dst-port=53 \
in-interface-list=LAN protocol=udp
add action=accept chain=input comment="Allow LAN DNS queries - TCP" dst-port=\
53 in-interface-list=LAN protocol=tcp
add action=redirect chain=dstnat comment=\
"Force Users to Router for DNS - TCP" disabled=yes dst-port=53 protocol=\
tcp src-address-list=!VLAN_Interfaces
"Force Users to Router for DNS - UDP" disabled=yes dst-port=53 protocol=\
udp src-address-list=!VLAN_Interfaces
In my case I dont care about VLANs with only access to the internet but everything else is forced if attempts are made to bypass the normal router setup.
Hello Anav, thanks for the quick answer!
I already use these rules and work well, but they do not work on the hotspot network unfortunately. There are clients who put a static DNS address and thus jump my router and resolve to the their DNS.
I think there must be some rule/s/ between the dynamic ones that are for hotspot ?
After the client’s authorization passes, the subsequent requests to the static DNS will be redirected to the router, I do not want to block them, but this happens quietly, as with the other networks!
Wow, okay that is good to know. I wonder why hotspot functionality bypasses NAT rules??
This is my question too !
I’ve understood that hotspot applies it’s own set of nat rules to control access, which usually (=default) get added in front and hence will take effect before existing rules.
But whatever nat is applied, you can control what passes the router: just block any other dns traffic in “/ip firewall filter chain=forward”
