I went through available instructions from online wiki, but I cannot get the Mikrotik hotspot to work. Any ideas?
Here is my config:
[admin@Mikrotik Router] > /export compact
# jan/02/1970 04:08:23 by RouterOS 5.25
# software id = XXXXXXXX
add admin-mac=D4:CA:6D:A6:53:77 auto-mac=no l2mtu=1598 name=bridge-local \
protocol-mode=rstp
/interface wireless
set 0 antenna-gain=90 band=2ghz-b/g/n channel-width=20/40mhz-ht-above \
country="united kingdom" disabled=no distance=indoors frequency=2417 \
frequency-mode=regulatory-domain ht-rxchains=0,1 ht-txchains=0,1 l2mtu=\
2290 mode=ap-bridge ssid="eduroam test" wireless-protocol=802.11
set 0 name=ether1-gateway
set 1 name=ether2-master-local
set 2 master-port=ether2-master-local name=ether3-slave-local
set 3 master-port=ether2-master-local name=ether4-slave-local
set 4 master-port=ether2-master-local name=ether5-slave-local
set [ find default=yes ] authentication-types=wpa-eap,wpa2-eap group-ciphers=\
tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik tls-mode=\
dont-verify-certificate unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=\
XXXXXXXXXX wpa2-pre-shared-key=XXXXXXXXX
add authentication-types=wpa-psk,wpa2-psk eap-methods=passthrough \
management-protection=allowed name=Open supplicant-identity=""
/interface wireless
add disabled=no l2mtu=2290 mac-address=D6:CA:6D:A6:53:7B master-interface=\
wlan1 name=wlan1-1 security-profile=Open ssid="eduroam setup test" \
wds-cost-range=0 wds-default-cost=0
/ip hotspot profile
add dns-name=eduroam.igor.local hotspot-address=192.168.1.200 login-by=\
http-chap,trial name=hsprof1 trial-uptime=2m/2m
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
add name=dhcp ranges=192.168.1.10-192.168.1.30
add address-pool=dhcp disabled=no interface=bridge-local name=default
add address-pool=dhcp disabled=no interface=wlan1-1 lease-time=1h name=dhcp1
/ip hotspot
add address-pool=dhcp disabled=no interface=wlan1-1 name=hotspot1 profile=\
hsprof1
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
add bridge=bridge-local interface=wlan1-1
add address=192.168.1.254/24 comment="default configuration" interface=wlan1
add address=192.168.1.253/24 interface=wlan1-1
add address=192.168.1.200/24 comment="hotspot network" interface=wlan1-1
/ip dhcp-client
add comment="default configuration" disabled=no interface=ether1-gateway
add address=192.168.1.0/24 comment="default configuration" dns-server=\
192.168.88.1 gateway=192.168.1.254 netmask=24
set allow-remote-requests=yes servers=192.168.1.2
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=\
ether1-gateway
add chain=forward comment="default configuration" connection-state=\
established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration" \
connection-state=invalid
add action=masquerade chain=srcnat comment="default configuration" \
out-interface=ether1-gateway
/ip hotspot user
add name=eduroam password=XXXXXX
/ip hotspot walled-garden
add dst-host=http://eduroam.igor.local
/ip neighbor discovery
set ether1-gateway disabled=yes
set wlan1 disabled=yes
set wlan1-1 disabled=yes
/radius
add address=192.168.1.52 secret=XXXXXXX service=wireless timeout=500ms
add address=192.168.1.53 secret=XXXXXXX service=wireless timeout=500ms
/system identity
set name="Eduroam Router"
/system leds
set 0 interface=wlan1
/tool mac-server
add disabled=no interface=ether2-master-local
add disabled=no interface=ether3-slave-local
add disabled=no interface=ether4-slave-local
add disabled=no interface=ether5-slave-local
add disabled=no interface=wlan1
add disabled=no interface=bridge-local
/tool mac-server mac-winbox
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
add interface=wlan1
add interface=bridge-local
[admin@Eduroam Router] >
You have problems with your ip subnets. You have wlan1 and wlan1-1 sharing the same subnet.
add address=192.168.1.254/24 comment=“default configuration” interface=wlan1
add address=192.168.1.200/24 comment=“hotspot network” interface=wlan1-1
Thanks for your help.
I removed the wlan1-1 from local bridge, and as you’ve suggested, I gave it a different network and NUT it, and it worked.
igortolk:
Next morning hot spot stooped working, or maybe it never even worked. Still need help here please.
here is the current config:
# jan/02/1970 01:52:35 by RouterOS 5.25
protocol-mode=rstp
/interface wireless
set 0 antenna-gain=18 band=2ghz-b/g/n channel-width=20/40mhz-ht-above \
country="united kingdom" disabled=no distance=indoors frequency=2472 \
/interface wireless
/ip hotspot profile
add dns-name=http://eduroam.igor.local hotspot-address=172.16.1.1 login-by=\
http-chap,trial name=hsprof1 trial-uptime=5m/5m
add name=hs-pool-8 ranges=172.16.1.10-172.16.1.100
add address-pool=hs-pool-8 disabled=no interface=wlan1-1 lease-time=1h name=\
dhcp1
/ip hotspot
add address-pool=hs-pool-8 disabled=no interface=wlan1-1 name=hotspot1 \
profile=hsprof1
add address=172.16.1.1/16 comment="hotspot network" interface=wlan1-1
/ip dhcp-client
add address=172.16.0.0/16 comment="hotspot network" gateway=172.16.1.1
/ip dns static
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here"
ether1-gateway
established
"place hotspot rules here" to-addresses=0.0.0.0
out-interface=bridge-local
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
src-address=172.16.0.0/16
/ip hotspot user
add name=admin password=XXXXXXXX
add dst-host=eduroam.igor.local
/radius
add address=192.168.1.52 secret=XXXXXXXX service=wireless timeout=500ms
add address=192.168.1.53 secret=XXXXXXXX service=wireless timeout=500ms
/system identity
/system leds
/tool mac-server
add interface=wlan1
I suggest removing the dns-name entry from “/ip hotspot profile”. If you use a dns-name entry, it must resolve to the hotspot interface ip, which in your case is 172.16.1.1.
When I type DNS name of the hotspot it resolves fine from the client on this ssid (I’m getting the hotspot page). Another thing is that when I type any DNS name of any website it does not redirect to the hotspot but when i type tje IP of any website, they all get quickly redirected to the hotspot DNS name.
Seem like a DNS problem?
I use external DNS server which is reachable through LAN ports of the router but wlan1 interface is on different network and doing NAT.
Here is updated config:
# jan/02/1970 00:47:04 by RouterOS 5.25
protocol-mode=rstp
/interface wireless
set 0 antenna-gain=18 band=2ghz-b/g/n channel-width=20/40mhz-ht-above country=\
frequency-mode=regulatory-domain ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 \
tkip,aes-ccm mode=dynamic-keys tls-mode=dont-verify-certificate \
unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=XXXXXXXX \
management-protection=allowed name=open supplicant-identity=""
/interface wireless
add disabled=no l2mtu=2290 mac-address=D6:CA:6D:A6:53:7B master-interface=wlan1 \
name=wlan2 security-profile=open ssid="eduroam setup test" wds-cost-range=0 \
wds-default-cost=0
/ip hotspot profile
add dns-name=eduroam.igor.local hotspot-address=172.16.1.1 login-by=http-chap \
name=hsprof1
add name=dhcp ranges=192.168.1.10-192.168.1.100
add address-pool=hs-pool-8 disabled=no interface=wlan2 lease-time=1h name=dhcp1
/ip hotspot
add address-pool=hs-pool-8 disabled=no interface=wlan2 name=hotspot1 profile=\
hsprof1
add address=172.16.1.1/16 comment="hotspot network" interface=wlan2
/ip dhcp-client
add address=192.168.1.0/24 gateway=192.168.1.254 netmask=24
add address=192.168.88.0/24 comment="default configuration" dns-server=\
192.168.88.1 gateway=192.168.88.1
/ip dns static
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" \
disabled=yes
ether1-gateway
add chain=forward comment="default configuration" connection-state=established
add action=drop chain=forward comment="default configuration" connection-state=\
invalid
disabled=yes
/ip hotspot user
set wlan2 disabled=yes
/radius
/system leds
/tool mac-server
add interface=wlan1
[admin@MikroTik] >
Then check your dns server. Is 192.168.1.2 an operating dns server?
Yes, 192.168.1.2 is the DNS server, and its working fine. As I mentioned earlier I could even ping the server IP from the client connected to the wlan2.
How does the hotspot fail? Just a blank page? When it fails, what is in the address bar of the client web browser?
Yes, when I type any URL it just displays a blank page, when I type any IP it automatically redirects to the hotspot URL address. Address bar just displays the unresolved URL, not redirection to the hotspot address.
Then your dns is malfunctioning. See if your router is resolving domain names. From a command prompt in the router:
:put [:resolve www.google.com]
Does it resolve that domain?
SurferTim:
It does not resolve it because its a local test DNS server that only resolved whats in the DNS list. Can this cause a problem with redirecting to resolvable hotspot URL?
Should I create Google entry in DNS to resolve to a local address for testing purposes?
Yes. If the dns server does not resolve domain names, it won’t redirect.
I’ve redirected DNS request to external DNS server and now wlan1 automatically redirects all clients to the hotspot URL.
