Hotspot doesnt want me......
Hello guys,
im on rb951-2n under load balancing pppoe client and wlan and i have the problem i will describe…
after finishing the hotspot setup, suddenly i disconnected from winbox and after that, nothing happens, no internet cannot access MT via winbox, absolutely nothing works.
Can someone help me plz and what u need of my configuration?
thnx in advance
i edit to post my entire configuration
set [ find default-name=ether3 ] master-port=ether2
set [ find default-name=ether4 ] master-port=ether2
set [ find default-name=ether5 ] master-port=ether2
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 max-mru=1500 max-mtu=\
    1500 mrru=1620 name=pppoe-out1 password=guest use-peer-dns=yes user=\
    guest@hol.gr
/ip neighbor discovery
set ether1 discover=no
add authentication-types=wpa-psk,wpa2-psk eap-methods="" group-ciphers=\
    tkip,aes-ccm management-protection=allowed mode=dynamic-keys name=USER \
    supplicant-identity="" unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=\
    !mixalis1998@ wpa2-pre-shared-key="THEPASS"
/interface wireless
set [ find default-name=wlan1 ] amsdu-limit=4096 amsdu-threshold=4096 \
    antenna-gain=12 band=2ghz-b/g/n channel-width=20/40mhz-Ce country=\
    "united states" disabled=no distance=indoors frequency=2417 hw-retries=6 \
    security-profile=Mixalis ssid=Mixalis tx-power=29 tx-power-mode=\
    all-rates-fixed wireless-protocol=802.11 wps-mode=disabled
/interface wireless nstreme
set wlan1 enable-nstreme=yes
add name=dhcp_pool1 ranges=1.1.1.100-1.1.1.150
add address-pool=dhcp_pool1 disabled=no interface=ether2 lease-time=1d name=\
    dhcp1
/queue simple
add max-limit=20M/1M name=pppoe-out1 queue=\
    pcq-download-default/pcq-upload-default target=pppoe-out1
add burst-limit=16M/850k burst-threshold=10500k/562k burst-time=8s/8s \
    limit-at=7M/375k max-limit=14M/750k name=QoS_1 packet-marks=QoS_1 parent=\
    pppoe-out1 priority=1/1 queue=pcq-download-default/pcq-upload-default \
    target=pppoe-out1
    limit-at=7M/375k max-limit=14M/750k name=QoS_2 packet-marks=QoS_2 parent=\
    pppoe-out1 priority=2/2 queue=pcq-download-default/pcq-upload-default \
    target=pppoe-out1
    limit-at=7M/375k max-limit=14M/750k name=QoS_7 packet-marks=QoS_7 parent=\
    pppoe-out1 priority=7/7 queue=pcq-download-default/pcq-upload-default \
    target=pppoe-out1
    limit-at=7M/375k max-limit=14M/750k name=QoS_8 packet-marks=QoS_8 parent=\
    pppoe-out1 queue=pcq-download-default/pcq-upload-default target=\
    pppoe-out1
/tool user-manager customer
set admin access=\
    own-routers,own-users,own-profiles,own-limits,config-payment-gw
add comment=defconf interface=ether2
add auto-isolate=yes
add address=192.168.1.1/24 comment=defconf interface=ether2 network=\
    192.168.1.0
add address=192.168.0.2/24 interface=ether1 network=192.168.0.0
add address=192.168.2.2/24 interface=wlan1 network=192.168.2.0
add address=1.1.1.1/24 interface=ether2 network=1.1.1.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
add address=1.1.1.0/24 gateway=1.1.1.1
set allow-remote-requests=yes cache-max-ttl=1d servers=62.38.1.81,62.38.0.81
/ip dns static
add address=192.168.1.1 name=router
add action=fasttrack-connection chain=forward comment="Enable FastTrack" \
add chain=forward comment="Accept forward established,related" \
add chain=input comment="Accept Input Established Related " connection-state=\
    established,related
add chain=input comment="Allow ICMP" protocol=icmp
add chain=forward comment="Accept Hamachi" dst-address=192.168.1.0/24 port=\
    60132 protocol=tcp
add chain=forward dst-address=192.168.1.0/24 port=60132 protocol=udp
add chain=forward dst-address=1.1.1.0/24 port=60132 protocol=tcp
add chain=forward dst-address=1.1.1.0/24 port=60132 protocol=udp
add chain=forward port=12975 protocol=tcp
add chain=forward port=32976 protocol=tcp
add chain=forward port=17771 protocol=udp
add chain=forward port=443 protocol=tcp
add chain=forward comment="Accept Torrent" dst-address=192.168.1.2 port=61132 \
    protocol=udp
add chain=forward dst-address=192.168.1.2 port=61132 protocol=tcp
add action=jump chain=forward comment="Make jumps to new chains" jump-target=\
    tcp protocol=tcp
add action=jump chain=forward jump-target=udp protocol=udp
add action=jump chain=forward jump-target=icmp protocol=icmp
add chain=icmp comment="echo reply" icmp-options=0:0 protocol=icmp
add chain=icmp comment="net unreachable" icmp-options=3:0 protocol=icmp
add chain=icmp comment="host unreachable" icmp-options=3:1 protocol=icmp
add chain=icmp comment="host unreachable fragmentation required" \
    icmp-options=3:4 protocol=icmp
add chain=icmp comment="allow source quench" icmp-options=4:0 protocol=icmp
add chain=icmp comment="allow echo request" icmp-options=8:0 protocol=icmp
add chain=icmp comment="allow time exceed" icmp-options=11:0 protocol=icmp
add chain=icmp comment="\"allow parameter bad\"" icmp-options=12:0 protocol=\
    icmp
add action=drop chain=icmp comment="deny all other types"
add action=drop chain=forward comment="Block \"bogon\" IP addresses" \
    src-address=0.0.0.0/8
add action=drop chain=forward dst-address=0.0.0.0/8
add action=drop chain=forward src-address=127.0.0.0/8
add action=drop chain=forward dst-address=127.0.0.0/8
add action=drop chain=forward src-address=224.0.0.0/3
add action=drop chain=forward dst-address=224.0.0.0/3
add action=drop chain=tcp comment="deny TFTP" dst-port=69 protocol=tcp
add action=drop chain=tcp comment="deny RPC portmapper" dst-port=111 \
    protocol=tcp
add action=drop chain=tcp comment="deny RPC portmapper" dst-port=135 \
    protocol=tcp
add action=drop chain=tcp comment="deny NBT" dst-port=137-139 protocol=tcp
add action=drop chain=tcp comment="deny cifs" dst-port=445 protocol=tcp
add action=drop chain=tcp comment="deny NFS" dst-port=2049 protocol=tcp
add action=drop chain=tcp comment="deny NetBus" dst-port=12345-12346 \
    protocol=tcp
add action=drop chain=tcp comment="deny NetBus" dst-port=20034 protocol=tcp
add action=drop chain=tcp comment="deny BackOriffice" dst-port=3133 protocol=\
    tcp
add action=drop chain=tcp comment="deny DHCP" dst-port=67-68 protocol=tcp
add action=drop chain=udp comment="deny TFTP" dst-port=69 protocol=udp
add action=drop chain=udp comment="deny PRC portmapper" dst-port=111 \
    protocol=udp
add action=drop chain=udp comment="deny PRC portmapper" dst-port=135 \
    protocol=udp
add action=drop chain=udp comment="deny NBT" dst-port=137-139 protocol=udp
add action=drop chain=udp comment="deny NFS" dst-port=2049 protocol=udp
add action=drop chain=udp comment="deny BackOriffice" dst-port=3133 protocol=\
    udp
add action=drop chain=input comment="Drop everything else" in-interface=\
    pppoe-out1
add action=drop chain=input in-interface=wlan1
add action=drop chain=forward in-interface=pppoe-out1
add action=drop chain=forward in-interface=wlan1
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface=ether1
add action=drop chain=forward connection-nat-state=!dstnat connection-state=\
    new in-interface=wlan1
/ip firewall mangle
add action=mark-connection chain=input comment=_____Load_Balance \
    in-interface=pppoe-out1 new-connection-mark=pppoe-out1_conn
add action=mark-connection chain=input in-interface=wlan1 \
    new-connection-mark=wlan1_conn
add action=mark-routing chain=output connection-mark=pppoe-out1_conn \
    new-routing-mark=to_pppoe-out1
add action=mark-routing chain=output connection-mark=wlan1_conn \
    new-routing-mark=to_wlan1
add chain=prerouting dst-address=192.168.0.0/24 in-interface=ether2
add chain=prerouting dst-address=192.168.2.0/24 in-interface=ether2
add action=mark-connection chain=prerouting dst-address-type=!local \
    in-interface=ether2 new-connection-mark=pppoe-out1_conn \
    per-connection-classifier=both-addresses-and-ports:2/0
    in-interface=ether2 new-connection-mark=wlan1_conn \
    per-connection-classifier=both-addresses-and-ports:2/1
add action=mark-routing chain=prerouting connection-mark=pppoe-out1_conn \
    in-interface=ether2 new-routing-mark=to_pppoe-out1
add action=mark-routing chain=prerouting connection-mark=wlan1_conn \
    in-interface=ether2 new-routing-mark=to_wlan1
add action=mark-packet chain=forward comment=QoS_1_ICMP-Echo new-packet-mark=\
    QoS_1 out-interface=pppoe-out1 passthrough=no protocol=icmp
add action=mark-packet chain=forward comment=______DNS_NTP dst-port=53,123 \
    new-packet-mark=QoS_1 out-interface=pppoe-out1 passthrough=no protocol=\
    udp
add action=mark-packet chain=forward comment=______ACK new-packet-mark=QoS_1 \
    out-interface=pppoe-out1 packet-size=0-123 passthrough=no port=!80,443 \
    protocol=tcp tcp-flags=ack
add action=mark-connection chain=forward comment=______HTTP-S_Small \
    connection-state=new dst-port=80,443 new-connection-mark=QoS_HTTP \
    out-interface=pppoe-out1 protocol=tcp
add action=mark-packet chain=forward connection-bytes=0-500000 \
    connection-mark=QoS_HTTP new-packet-mark=QoS_1 passthrough=no protocol=\
    tcp
add action=mark-connection chain=forward comment=QoS_1_LOL_Client \
    connection-state=new new-connection-mark=QoS_1 out-interface=pppoe-out1 \
    port=5000-5500 protocol=udp
add action=mark-packet chain=forward connection-mark=QoS_1 new-packet-mark=\
add action=mark-connection chain=forward comment=QoS_1_Hamachi \
    port=12975,32976,443 protocol=tcp
add action=mark-connection chain=forward connection-state=new \
    new-connection-mark=QoS_1 out-interface=pppoe-out1 port=17771 protocol=\
    udp
add action=mark-connection chain=forward comment=\
    QoS_2_FTP_SSH_Telnet_SMTP_POP3-S_SNTP_IMAP-S_SMTP-S connection-state=new \
    dst-port=20,21,22,23,25,110,143,465,587,993,995 new-connection-mark=QoS_2 \
add action=mark-packet chain=forward connection-mark=QoS_2 new-packet-mark=\
    QoS_2 passthrough=no
add action=mark-packet chain=forward comment=QoS_2_HTTP-S_Large \
    connection-bytes=500000-0 connection-mark=QoS_HTTP new-packet-mark=QoS_2 \
    passthrough=no protocol=tcp
add action=mark-connection chain=forward comment=QoS_8_Torrents_except_VoIP \
    connection-state=new new-connection-mark=QoS_8 out-interface=pppoe-out1 \
    port=3000,6881-7000,9091,10000-65535 protocol=tcp src-port=!1167
    new-connection-mark=QoS_8 out-interface=pppoe-out1 port=\
    3000,6881-7000,9091,10000-65535 protocol=udp src-port=!1167
add action=mark-packet chain=forward connection-mark=QoS_8 new-packet-mark=\
    QoS_8 passthrough=no
add action=mark-connection chain=forward comment=QoS_7_VoIP_and_all_others \
    connection-state=new new-connection-mark=QoS_7 out-interface=pppoe-out1
add action=mark-packet chain=forward connection-mark=QoS_7 new-packet-mark=\
    QoS_7 passthrough=no
add action=masquerade chain=srcnat comment="Basic NAT" out-interface=\
    pppoe-out1
add action=masquerade chain=srcnat out-interface=wlan1
add action=dst-nat chain=dstnat comment="Allow Hamachi" dst-port=60132 \
    in-interface=pppoe-out1 protocol=tcp to-addresses=192.168.1.2 to-ports=\
    60132
add action=dst-nat chain=dstnat dst-port=60132 in-interface=wlan1 protocol=\
    tcp to-addresses=192.168.1.2 to-ports=60132
add action=dst-nat chain=dstnat dst-port=60132 in-interface=pppoe-out1 \
    protocol=udp to-addresses=192.168.1.2 to-ports=60132
add action=dst-nat chain=dstnat comment="Allow Torrent" dst-port=61132 \
    61132
add action=dst-nat chain=dstnat dst-port=61132 in-interface=wlan1 protocol=\
    tcp to-addresses=192.168.1.2 to-ports=61132
add action=dst-nat chain=dstnat dst-port=61132 in-interface=pppoe-out1 \
    protocol=udp to-addresses=192.168.1.2 to-ports=61132
add action=masquerade chain=srcnat comment="Access modem" out-interface=\
    ether1 to-addresses=192.168.1.10
add check-gateway=ping distance=1 gateway=pppoe-out1 routing-mark=\
    to_pppoe-out1
add check-gateway=ping distance=1 gateway=192.168.2.1 routing-mark=to_wlan1
add distance=1 gateway=192.168.0.1
add distance=2 gateway=192.168.2.1
/system clock
set time-zone-name=Europe/Athens
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set pppoe-out1 disabled=yes display-time=5s
set wlan1 disabled=yes display-time=5s
set ether1 disabled=yes display-time=5s
set ether2 disabled=yes display-time=5s
set ether3 disabled=yes display-time=5s
set ether4 disabled=yes display-time=5s
set ether5 disabled=yes display-time=5s
/system leds
set 0 interface=wlan1
/system ntp client
set primary-ntp=62.103.129.253 secondary-ntp=194.177.210.54
/system package update
set channel=bugfix
/system routerboard settings
set cpu-frequency=400MHz
/tool mac-server
add
/tool mac-server mac-winbox
add
/tool sniffer
set filter-interface=*10 streaming-enabled=yes streaming-server=10.10.10.1
/tool user-manager database
set db-path=user-manager
My setup is …
ether1= my pppoe client connected to 192.168.0.1 bridge modem masquerade, added also 192.168.0.2 masquerade to be able to access my modem
ether2= my lan added 2 ip’s 192.168.1.1/24 and 1.1.1.1/24, on second dhcp acts
wlan1= has the 192.168.2.2 ip and connects as bridge mode on an external 192.168.2.1 modem and load balances with pppoe client, masquerade also.
My setup has no any bridge interface
I have no problem working with the above configuration, but when im going to setup the hotspot, after finishing, everything disconnects and i cant even access the MT via winbox, also no internet access and i have to reset the MT and restore my configuration to make it work.
I have tried to delete the second lan (1.1.1.1) and the dhcp server but with no luck.
In begin i remember that i was able to setup the hotspot with success, exactly after pppoe setup but i delete it cause i was not sure if i want it and then i setup all the other config i have now, load balance, QoS in simple queue, simple firewall and now i cant setup the hotspot.
Any farther help will be appreciated cause i have stack on this
Does it happen when you enable the hotspot?
If you enable hotspot on a interface you are connected to it will disconnect you
If you are trying to connect to the same interface as you have implemented the hotspot on, then you have two options:
1- connect with MAC
2- open the browser and put your interface address and try to use the same login information as it was required to setup hotspot. Walla , you can connect to winbox with ip now.
keep us informed
Sent from my SM-N910C using Tapatalk
