Hotspot dont pass SSL traffic after login
Hello !:slight_smile:
I have a problem with hotspot plugin in my routerboard. First I have RB450G with 6.33 and hotspot plugin. Everything works fine. Now i must migrate to RB2011UiAS-RM.
I make the same basic configuration like in RB450G. And now when I sucesfull login to hotspot account my router don’t pass SSL traffic (ex. gmail), but when i login used usermanager account it’s works fine.
On RB2011 i test it on 6.33.5, 6.34.6 and 6.35.4.
On my preverious router (450g) SSL traffic pass both on user manager and hotspot accounts.
Mayby someone has the same problem, i don’t now how to solve this :slight_smile: Please help :slight_smile:
@Edit
I noticed, when i do few logins uses both accounts then my router don’t pass any traffic. In the same time when i connect to port without hotspot it’s work ok.
Provide an export of your current firewall rules “/ip firewall export” this will include all filter rules, NAT rules, and mangle rules. Also please provide “/ip route print”, “/ip address export”, and “/ip hotspot export”.
These are the most relevant parts of your configuration in regards to the hotspot. Chances are it is some firewall rule that is preventing the communication, but without that information no one on the forums can really help pin point the issue you are running into.
I reapired me problem. Mayby it’s helpful for someone.
When i have default firewall configuraton, me probles exist, but when i disabled below rule everything works ok
