I’m using hotspot with bandwith limit (‘rate limit’ in hotspot user profile). It creates dynamic queue when user logins but any of exist static queues don’t working! I want to use static and dynamic queues simultaneonly.
For all hotspot users I need to set 10Mbps speed for access to some servers but ‘rate limit’ speed for access to other resources.
You are not alone in your interest.. There is many people on the forum who wanna know something about. I asked several times there but don’t having any answer at this day.
I guess one of the method to accomplish it by using scripts, you can create ‘on-login’ scripts for HotSpot profile, that will move static queues on top.
Now static queue is above than any dynamic but hotspot user (hotspot-user3) has 48kbps all the time when local resource (10.10.1.2) used!
I need to set 256kbps when local 10.10.1.2 used and 48kbps when any other. How do accomplish it?
It is possible to use static queues and dynamic queues.
Dynamic queues are applied for entire traffic (you should place them at the bottom of the list), static queues for specific resources should be placed on the top.
Use interface=all for ‘queue simple’, it should work.
