Hotspot external SSL page - error sending login to http
Hi All
Im hoping someone can help on this:
I redirect all my hotspot captive portal files to an external server with its own SSL cert. When sending the login form back to MikroTik to instigate a login , I get a warning that the data is not secure as its coming from an SSL site, posted to HttP: site (10.5.50.1)
How best to resolve - any ideas?
Import an SSL cert on the router and set the login method on the Hotspot server profile to HTTPS, referring to the installed cert.
You’ll also need to ensure your hotspot profile is setup using a dns name that matches what the SSL certificate was made for.
Ive found another way around this problem , transfering the login credentials from the website to a non ssl page on the same server using the session variables, and then posting the non ssl version back to Mikrotik. Password is encrypted anyhow so non SSL authentication is fine.
Users are happier though usingg SSL on the main sign up pages and save me the hassle of having loads of SSL certs to pay for (self signed not being an option)
thank you all.
You can use wildcard certs just fine, or alternatively use the same internal DNS name everywhere. I use hotspot.company.com mapped to 10.1.0.1 and have a VLAN interface on all Hotspot routers that carries that IP address. Bought one cert for that name, and use it on all my Hotspot routers.
