I’ve x86 router running by ROS 4.17 with 3 intrfaces
- WAN 10.10.10.10/30 (transport network to ISP)
- DMZ 11.11.11.11/27 (routed network from ISP with some external hosts running web and etc..)
- LAN 172.16.1.1/24 (local hosts placed here)
LAN interface also running Hotspot with Radius auth on local AD with no problems. LAN users can access DMZ without any NAT. Ip-binding feature is disabled on Hotspot & DHCP also disabled on ROS, local stations use wheir own adresses leased by MS Windows DHCP.
So grand question ![]()
User point their IE to go to anyplace, then hi/she’ll see login page and fill their login/pass, after auth, we’ll see his/her activity in billing (for examp - UserManager or any other, that can use Radius). In my configuration example i don’t need to bill user’s traffic to/from DMZ and i’ve free access to some external networks running by my ISP. So, using winbox hotspot config, I can’t exclude some hosts/networks from “billing” after user authorisation and I see all their traffic in “billing”, even then they go to hotspot’s status page. And, as you can see, WallGarden and ip-binding is helpless in this case ![]()
Can someone help?
