Hi guys,
Anybody know were can I found the explanation of the dynamic rules and “variables” (“auth”, “to-client”, “from client”) that use Hotspot?
thanks you very so much!
Regards
Hi guys,
Regards
HotSpot firewall rules described here,
http://www.mikrotik.com/testdocs/ros/2.9/ip/hotspot_content.php#7.41.14
I do not undestand your question. Any user can navigate walled-garden pages, registred user may navigate all pages. If you need configuration that registred user will be able to navigate only few pages, then additional static firewall rules will be reuqired to accomplish this.
My system works as following:
I tried to use pre-hs-input chain in filter to reject packets with the “Account_Disabled” mark, but I do not know the reason it isn’t working.
Regards
