I need help.
I followed the steps on the how to hotspot
and isnt working
when I open any web it doesn’t redirect me to the logging webpage, I see that i can resolve hosts, so the dns is working.
what im doing wrong?
I got the client ip address asigned
my wlan1 is 192.168.0.1
and my eth1 is 192.168.0.4 , gw is 192.168.0.3
Can anyone give another guide to set up a hotspot?
Do i need to set an httpd server on mikrotik?
Log doesnt say anything
How can I debug my hotspot?
I ve readed the how to, and the manual pages.
Thank you
normis
3
hotspot is the easiest thing in RouterOS to make!
In short steps:
- enable interfaces, call one
public - other local
- set IP addresses
- add default route, add masquerading rule (check if internet works from the PC behind it).
- run hotspot setup in winbox and fill in the basics (you don’t need certificate, SMTP server IP and DNS name, those leave blank).
I did that :S
But i get no error
The redirection isnt work
I can’t see the login webpage
i cant see it even if i go to http://my_hotspot_public_ip_address
reset your config, and follow the steps i wrote. if it doesn’t work, i suggest you to hire a consultant or attend a training
