Hotspot for guest and wifi for employees on one device
I have an RB-951G This is connected with Ether1 and Ether 2 to my modem/router
The modem router is configured that port 1 and 2 are different networks
Ether 1 is for employees and without nat
I like to have ether2 for Guests
So if a guest login on the WiFI to the hotspot he must get an IP and his connection must go over ether2.
My normal traffic for employees must go over ether1 (without nat).
Is this possible?
Your post is not very clear of what you are trying to achieve. Can you try again?
Sure,
I try to explain.
I have a modem/router with multple LAN ports.
Port 1 is for normal use and it is running DHCP.
Port 2 is for guest and is static IP
I like to use an RB-951G and create 2 Wifi profiles. 1 profile for normal users and 1 profile for wifi guests.
I want to configure HOTSPOT on the RB-951G and let Guest login there.
If they are logged in the can internet and use PORT 2 from the modem/router as gateway.
All other users (normal users in the netwerk) get an IP from the DHCP server wich is running on PORT 1 of the modem/router and so use PORT 1 as gateway.
Hope you understand what I mean.
Do you understand my explination of what I want?
Do you have another router in addition to the 951?
Yes,
I have an Sonicwall and that is connected to the modem.
The sonicwall is doing NAT and IPS/IDS
So I like to use that allso.
