Hi all,
we has one client that always complain about the hotspot system we installed for them.
The system using RB433, WLM54G plus rubber duck 9 db antenna and the area covered is about 50 meters radius.
The user profile setup as followed :
[admin@MikroTik] /ip hotspot user profile> prin
Flags: * - default
0 * name=“default” idle-timeout=15m keepalive-timeout=10m status-autorefresh=1m shared-users=1 transparent-proxy=no
The above setup have been implemented on various locations and only this client that always complain about frequently disconnected and followed by wrong username & password, user already login and try javascripts.
Within sudden inspection, I found that this client wooden building has aluminium foil surround and I suspect this aluminium foil is the problem source.
Can anyone give me the suggestion about this problem ?
Paul
