HotSpot Gateway
Anyone can help how can i setup mikrotik as hotspot gateway, what kind of interface do i need or just two ethernet cards only. Any help would be appreciate. Thank you
yes,
you can use 2 nic ethernet cards enough, than call one as public interface and other one as local interface, also setup with hotspot wizard follow screen report and put hotspot server on local interface
regards
Hasbullah.com
so u mean i need another hotspot server integrated with mikrotik os? i did look an example on wiki on setuping hotspot gateway but unsuccessful. It seems like i do need minipci/pci wireless card on mikrotik os.
no,
you can build it with same machine is effective
regards
Hasbullah.com
you need one RouterOS machine with at least two ports (one for client network, other for internet connection to ISP). configure RouterOS so that insternet works, and then in Winbox go to the Hotspot section and click on SETUP. that’s all
Thanks for the help, i managed to setup a hotspot and it’s quite an easy things if we follow up the setup and of course the help of u guys. Thank you
hai fren,
later, nice recommend will try complete feature with 'Userman' manage your user for.
you will seat and count your benefit by yourself. :wink:
regards
Hasbullah.com
Hi Balimore,
I have read all the documentation of userman and seems like i’m going to try it. First of all, i just wanna ask u how can i install, as currently i’m using Mikrotik OS on DOM, is it possible to install it inside my DOM or do i need another harddisk. Currently i’m using DOM as my primary Mikrotik OS and another harddisk for running my web proxy on Mikrotik OS.
walla
Hai walla
i hope you will success with it, and i think you have luck because last year ago i started wihout enough documents. so you will read and start this complete document at here: RouterOS - RouterOS - MikroTik Documentation
regards
Hasbullah.com
Hi Balimore,
Can;t install the package of userman as my mikrotik os version on my DOM is 2.9.20 and the current version of userman is 2.9.43.. is it possible for me to search the same version with my mikrotik, if so where to download…
thanks
walla
Hai Fren,
yes, you can't install when different version package to your machine.
read this you have same problem with other person at here: can not install user-manager-2.9.43
regards
Hasbullah.com
yes, you have to upgrade to 2.9.43
upgrading is free and easy, no reason to not do it
i did check on my license..
software-id = “xxxx-xxx”
upgradeable-until= may/01/2007
nlevel = 4
wondering whether is it still possible for me to upgrade, as currently i’m using Disk On Module, i afraid after i upgrading my DOM won’t work anymore.
Any recommendation??
use Netinstall to do it. There are no more time limits for upgrading, netinstall will take care of it. make sure you have a backup anyway
