HOTSPOT help...
heya
i want to use Hotspot so all my clients when they want to use internet open a page and put username and password of no internet i did everything ok
from Radius server then at ip/Hotspot
i add dst and dst port
now i come to the file i drag the login to the desktop edit it and then change the site to the ip of my mikrotik and then when i try it don’t work!
any clue
i did everything as what’s showing me here :
http://www.aradial.com/DownLoads/Mikrot … -Guide.pdf
but when i open the page don’t ask me for username ans password
i need it i hope someone can help me with.
Thanks for your Help.
well, i have leanrt that trying to change the hotspot username and password entries, could mess up things. So i hope that is not the pro? Does it connects when you use the default hotspot page? Maybe you should explain further…
Hi, I’m running small isp on mikrotik os 3.20. All my client are connected to Ap by HotSpot+Radius+user-manager. Also You can make own login page(so I did:-). All works great and easy. All this simply config. could be done in 15min- just read http://www.mikrotik.com/testdocs/ros/3.0/ or “miki-wiki”.
Ps: “well, i have leanrt that trying to change the hotspot username and password entries, could mess up things”- Remeber to clean up the cookies on the client web browser site or HotSpot server.I nerver had any problems with change the login-name or password for my clients.
Regards
thanks all it work
i have PPPoe Client 3
one 4 me and 2 for my friends i open them in Mikrotik
they told me you can speed your bandwith with these 3 PPPoe Client such as pages/download
from ip route rule ?
can anyone show me how thanks alot.
