Hotspot help
Dear all,
Using Radius Manager and Mikrotik hotspot
Is it possible for Hotspot to handle multiple concurrent connections from a NAT-ted or Routed network? I know that hotspot uses MAC address associated with the IP address and so by default it only accepts single login per MAC/IP.
Basically the design would be, Mikrotik hotspot with /30 LAN interface → connected to a company router or routing device → users computer - the requirement is to have multiple users connected at the same with their own username/password (authenticated from a radius server).
Thanks in advance.
Harold
Hello, can somebody reply if that is possible or not?
Thanks in advance.
