Hello Guys !!!
I’m new with Mikrotik I have my HotSpot running well under a RouterOS v6.0rc14. My HotSpot It’s running with the default configuration of HotSpot using authentication by username + password on the login page !
I need to change my authentication type… My HotSpot will be a free hotspot and don’t need username + password the customer only needs to put his ID and Email and click on the confirm button to surf on the web… But I need to be able to check after in any report the association between the ID and the IP Address used If the customer has used the service to do bad things !!!
So:
Is it possible to configure Mikrotik HotSpot to login without username + password ? In the same page has any variable that I can put in my Webpage to Mikrotik associate with the Ip addres used by the customer ?
Tks !!!
