My hotspot is working just fine on my local premises. However, I want it to allow users about a kilometer away to also use it.
I use two Rocket M2 Titanium units to create this wireless link to the other premises. The rockets have two lan ports. I therefore run the hotspot access point from the one lan port on the range 192.168.3.x and the other lan port I want to use for IP cameras, using 192.168.0.x. The access point is a Bullet M2 Titanium, one at each premises. All hardware using static IP’s.
On the local site, the Bullet M2 AP work 100% with the hotspot.
However, the Bullet M2 (AP) on the far side, behind the Rocket link, refuse to display the hotspot.hot/login page. I use my android phone to connect and get an IP from the RB532’s DHCP server pool, but the hotspot see it as unauthorized, it seems like, and will not allow it to go to the login page. I added ARP to the DHCP server, but still no go. There is no difference with or without ARP.
When I try to connect to the hotspot, I can see the ip, allocated to the android, in the hotspot hosts tab, with an AH prefix, same as local devices login on. So I am definitely reaching the RB532 hotspot over the link.
On the remote site, when I type 192.168.3.1 (ether1, hotspot) into the browser, it redirects to hotspot.hot/login , but display page not found. Yet this is not happening on the local site, not going through the point to point link and using the exact same model access point. It redirects the same way and the login page is displayed.
SurferTim, I sure hope you are going to see this post and help me out! Some fancy rule? hehe
