Hotspot: how to passthrough without authentication?
Hello!
The situation is i have enable hotspot for my mikrotik and it assigns ip address to my clients.
However, there’s a device which called WSG which is a wireless gateway connects to my mikrotik. What settings can i use so that the WSG does not need authentication from the mikrotik hotspot? I want it to passthrough without authentication from the hotspot mikrotik.
thanks.
you may use HotSpot ‘ip-binding’ feauture, set to desired address action=bypass.
http://www.mikrotik.com/docs/ros/2.9/ip/hotspot||0.978932463743242
thanks sergejs! i can get it done now! thank u. :smiley:
