I was wondering if the dymanic drop all firewall rule that gets added to the hs-unauth chain is supposed to there. It blocks all connections. I can’t even get to the login page, or ping the gateway till I remove the rule. It assigns me a lease but doesn’t allow any traffic through. Is this a bug or is there something in my config that is wrong.
[admin@MikroTik] ip hotspot> print detail
Flags: X - disabled, I - invalid, S - HTTPS
0 name="server1" interface=Hotspot address-pool=dhcp_hotspot profile=default
idle-timeout=none keepalive-timeout=none
[admin@MikroTik] ip hotspot user> print detail
Flags: X - disabled
0 name="test" password="" profile=default uptime=0s bytes-in=0 bytes-out=0
packets-in=0 packets-out=0
Thanks,
D~
