Here is problem:
Access list in Web-proxy (ip web-proxy access) does not work transparently with Hotspot. But if I specify manually in web-browser, it works fine.
I have gone through similar topic in the same forum which says we should not use Trasnsparent proxy in “ip hotspot user profile”. I tries that but it still adds up following dynamic NAT rule in HS-AUTH;
12 D chain=hs-auth protocol=tcp hotspot=http action=redirect to-ports=64874 (64874, i understand is wall garden proxy server port)
I tried to remove the same & key in new similar one with to-ports=3128. It worked for access list but hotpot pages stopped working. Also when I reboot above dynamic entry will pop up again.
Any input will be highly appreciated[/b]
