Hi i just created a virtual ap to use it as hotspot, i can see the new ssid without issues and connect but machine not getting the new lan 10.5.50.x its getting the main wlan ip 192.x.x.x.
how i can fix this?
thank you very much.
how i can fix this?
Can you post your config?
Have you the virtual accesspoint give a IP-address? en configure a DHCP-server on it?
You must also nat en masquerading the IP_pool in firewall nat
alexistkd, is this something that you still need help with?
