hotspot ip-binding problem urgen please help
Hi Guys.
I have hotspot setup and I’m having problem with it
As soon as I turn on login page users start logging in work for 2 min good and start slowing down the internet and than will come a point where you can’t open anything. Is like NAT problem or I dont’ know but looks like as soon one user logon all other users share that traffic . I have limited my users at 512 kilobits . But if I binding my ip range all users can go online and work just fine.
What can be a problem is really urgent .
any help I really appreciate
I will look for any reply
thx
Selim
Try to disable transparent-proxy=no in /ip hotspot user profile.
hi sergejs
sergejs first of all many thanks for your replay .
I stop the transparent proxy on user profile and will try it and come back to you ..
thanks.
take care
selim
hi sergejs
I just test it and looks working good. But login page is coming slow looks like DSN problem.
Because if you type local ip address of server which on this case I have ip address of server 12.10.10.1 the login page come right away but if you just try to surf and login come little slow.
But I can tell man you are life saver.
Any other suggestion I highly a appreciate.
Take Care
Selim
Hi sergejs
It’ working prefect I can tell that ..
Sergejs just sometime the login page doesn’t come up fast it’s like sitting there for a while and or you have to wait a little bit or you have to close the browser after that bring the loogin page.
Also during the surf not quiet often but I get the page can’t be display .
The for you support
take care
Selim
