Hotspot Issues (blocks devices traffic) randomly
With the hot-spot enabled these device cannot ping 10.0.0.1 (default gateway ip / hotspot server) or anything passed the hotspot router to the internet. The devices can however ping other devices on the network.
Devices that are in the bypass list with a static DHCP have the same issue.
I can ROMON to the guest routers from the hotspot.
If i disable the Hotspot and re-enable everything works as required. This issue randomly happen and has happened historically on 3 different hardware types when it was a RB450 upgraded to a RB850 now we use and RB1009. The same configurations was used for all 3 upgrades.
Next time it happens I will romon to different devices and see it the are all having the same problems.
Thoughts and Thanks
Bill
