Hotspot Keepalive Timeout
What method does the MT use to determine that the user is still connected? I know it is not via pinging since I am not able to receive a response from a number of our clients since their routers are set not to respond to ping requests - but those customers still stay connected.
I am asking this since we are testing a new network setup and our test client keeps getting kicked off after 2 min (which is our timeout setting) when he gets connected to a VPN server, sends a large e-mail, or other continual bandwidth applications. But, if he is just performing basic web surfing or e-mail, his connection works just fine.
Any thougths? Or at least some input as to how the MT communicates to the client to determine they are still active.
send support@mikrotik.com your supout.rif file that was made right after the client is disconnected. also make sure you use 2.8.23
i’m having similar problems. A client can be connected for just a few minutes, and then gets kicked out. Bad enought that it’s agervating just trying to browse the web. I dont have any specific timeouts set, and the time they disconnect is at any certain period.
Also, where can the supout.rif be found?
http://www.mikrotik.com/docs/ros/2.8/system/support.content
I was have same problems …
client computers with XP SP2 must alow in firewall icmp for IP of router.
Also same princip for other firewalls …
