Hotspot kill N Computing
Hi there,
we has the new MT with hotspot installation and having surprise with an existing N Computing network.
the N Computing running fine before MT installed.
the MT ip address is 192.168.101.33/28
the N Computing server address is 192.168.101.46/28
and the clients are using the address in between.
The problem start detected when the hostpot server turned on where all of N Computing clients could not see the server. The problem solve with the hotspot server turned off.
So, has anyone of you having the similar situation ? If so, how to solve this problem ?
in sort, we want N Computing can run as expected when the hotspot server turned on.
TIA
PD
