hi, im using mikrotik 3.20 to create a hotspot point.
it worked OK for a couple of weeks,then i got a call from a LAN user (no wifi ,not connected to hotspot box) that, he got a message on his browser, that asks him a username/password. which is hotspot login page.
i guess,a user has a bridge between his wireless and LAN adapter that is probaby windows’ sharing internet feature or something like that.
and since mikrotik hotspot is likely doing some arp poisoning (not sure,but i guess that also), the LAN users are spoofed immediately i turn on the mikrotik box. (i had to shut down it on the first call)
if that user accidently connected to your wireless hotspot network, and got the login screen - that is what’s supposed to happen. tell him not to connect to other unknown netoworks, and turn off the wifi card when not using it.
how can you deny your client’s to use bridge? they can use whatever software they want, can’t they? this is like running another DHCP server in the network - it will also cause major problems.
if someone from LAN complains, tell him that the reason is that user with bridge - it’s not your trouble! why the hell should you answer the malicious actions of other users?
ooooooooops if its really an ARP poisoning (i wish is is not) only GOD can save you. if suffer a lot by this issue and my entire wisp network become a fish market. but i don’t know how i came out with it, i remember i disallow all the wlan interface and allow them one by one only after formating the computer and installing a decent anti-virus in each computer.
then only i was able to was able to make my network stable agian
