Hi
I’m not sure what I’m doing wrong but the hotspot authentication page (login.html) isn’t displayed automatically anymore
The users have to navigate to http://www.google.fr or http://1.1.1.1 to force the login page to show up
Is there a parameter, or more, that I haven’t setup properly or is this functionaly no longer operational ?
thanks
yann
Hi
if android version is 5 or higher and ios is 9 or higher or windows 8.1 or 10 then login page open automatically but in old operating systems it will not run automatically.
Ok, thanks MJSabri
I’m surprised by the OS levels you indicated:
I’m practically certain that this used to work with older OS versions before.
I suppose it must be the newer ROS that has brought about this restriction
Hotspot supported in new OS but in old OS you should go to browser and open a website then login page will be load for you.
