Heloz,
is it possible ?
The hotspot server is on the bridge and so far , I think I was able to get dhcp lease from the server by inserting rules in the filter to accept certain udp ports
add chain=hs-unauth-to protocol=udp src-port=68
add chain=hs-unauth-to port=137 protocol=udp
add chain=hs-unauth-to dst-port=67 protocol=udp
I can login to the hotspot by putting the ip in the url address directly , after i log in , i can't even ping the gateway
would this work?
redirect to hotspot to authenticate (
Address list for authenticated users to exclude from hotspot
Please help , I have faith in you ![]()
