Hotspot / local access points reachable over vpn
I have a hotspot setup with vpn connection to radius server and for remote control purpose.
The local access points are in the same subnet like the client ip’s:
infrastructure vom x.x.x.2-32 , hotspot client ip’s from x.x.x.33 - x.x.x.254
All access points have fixed ip’s in the specified range, but also get an ip from the hotspot by dhcp.
I can see them in hotspot / hosts.
For this reason this access points are blocked to reach them over the vpn.
Only when I bind the IP to the mac-address by “ip-Binding” it is working.
Is there maybe another way to specify the range which had to be reachable and not blocked by hotspot masquerading.
kind regards,
Paul
You can disable the 1:1 NAT in the hotspot. That way the static ips will not be translated.
/ip hotspot
set 0 address-pool=none
You have a dhcp server on the hotspot interface, correct?
Yes the dhcp server is local on the RB.
So I can define a second address pool x.x.x.0/27 which will exclude with your command the ip address from 1-32.
Correct?
Kind regards
Paul
