Hotspot - Login frequency.
Hi all!
I have a couple of clients complaining about the frequency the login page shows up.
For example they have an iPhone and login then check mail or something and they put it in standby, and then in 10 minutes need to check anything else and the hotspot asks again the login, so..
its there a way to once the user is logged in, increase the time to 24hrs or something similar?
Thanks in advance.
JB
Take a look at hotspot session/keepalive/idle timeouts parameters .. The key is there
use cookies at IP - HOTSPOT
Thanks..i will take a look at.
I have selected in the hotspot profile Cookies and http chap (defaults)
and cookie lifetime 1d.
cookies work if users open a browser after the standby period, but they do not help if hotspot session is up and they only use other clients (mail, whats’up,..)
Thanks @bajodel
Worked like charm, but i have a couple of clients that are using radius to login and im not using user profiles? where can i define this values?
Thanks in advance.
JB
take a look here >> http://forum.mikrotik.com/t/hotspot-radius-profiles/47694/1
