Hotspot login page does not load automatically
I am using RB750UP v5.24. I am not not getting the hotspot login page when I open my browser and try to go to a website. The page only comes up if I go directly to the hotspot address
http://10.0.0.138.
any suggestions welcome.
if your hotspot properly config, it will automatically redirect you to hotspot login page. there is something wrong with your config.
Please post your hotspot config.
See my config below:
[admin@MikroTik] > /ip hotspot export verbose
aug/06/2013 10:05:23 by RouterOS 6.2
software id = 1REW-4B4J
/ip hotspot user profile
set [ find default=yes ] add-mac-cookie=yes address-list="" idle-timeout=10m keepalive-timeout=5m mac-cookie-timeout=3d name=default rate-limit=256k/1024k shared-users=1 status-autorefresh=1m
transparent-proxy=no
/ip hotspot profile
set [ find default=yes ] dns-name=127.0.0.1 hotspot-address=127.0.0.1 html-directory=hotspot http-proxy=0.0.0.0:0 login-by=http-chap,http-pap,trial name=default nas-port-type=wireless-802.11
radius-accounting=yes radius-default-domain="" radius-interim-update=received radius-location-id="" radius-location-name="" radius-mac-format=XX:XX:XX:XX:XX:XX rate-limit="" smtp-server=0.0.0.0
split-user-domain=no trial-uptime=30m/1w trial-user-profile=default use-radius=yes
add dns-name=10.0.0.138 hotspot-address=10.0.0.138 html-directory=hotspot http-proxy=0.0.0.0:0 login-by=http-chap,https,http-pap,trial name=AIsleComHotpsotG nas-port-type=wireless-802.11
split-user-domain=no ssl-certificate=none trial-uptime=30m/1w trial-user-profile=default use-radius=yes
/ip hotspot
add disabled=no idle-timeout=10m interface=hotspot_bridge keepalive-timeout=none name=AIsleCom_Gouyave profile=AIsleComHotpsotG
/ip hotspot ip-binding
add address=10.0.0.2 disabled=no server=AIsleCom_Gouyave type=bypassed
add address=10.0.0.3 disabled=no server=AIsleCom_Gouyave type=bypassed
/ip hotspot service-port
set ftp disabled=no ports=21
/ip hotspot user
add disabled=yes name=admin password=xxxxxxx profile=default
/ip hotspot walled-garden
add action=allow comment="place hotspot rules here" disabled=no !dst-host dst-port="" !method !path !server !src-address
add action=allow disabled=no dst-host=api.stripe.com dst-port="" !method !path !server !src-address
add action=allow disabled=no dst-host=checkout.stripe.com dst-port="" !method !path !server !src-address
add action=allow disabled=no dst-host=api.mixpanel.com dst-port="" !method !path !server !src-address
/ip hotspot walled-garden ip
add action=accept disabled=no dst-address=10.10.10.10 !dst-port !protocol !server !src-address
add action=accept disabled=no dst-address=5.10.73.0/24 !dst-port !protocol !server !src-address
add action=accept disabled=no dst-address=75.126.58.194 !dst-port !protocol !server !src-address
add action=accept disabled=no dst-address=50.18.169.156 !dst-port !protocol !server !src-address
add action=accept disabled=no dst-address=50.18.195.3 !dst-port !protocol !server !src-address
add action=accept disabled=no dst-address=50.62.227.1 !dst-port !protocol server=AIsleCom_Gouyave !src-address
add action=accept disabled=no dst-address=67.215.190.43 !dst-port !protocol server=AIsleCom_Gouyave !src-address
try this
/ip hotspot profile
set [ find default=yes ] dns-name=127.0.0.1 hotspot-address=10.0.0.138
I’ve had an issue for the past year where the hotspot login notification wouldn’t be displayed on my huawei phone,
but today after updating ( EMUI8 to WAS-LX1A 8.0.0.397C185 ) the issue was fixed inexplicably and the notification would show up after connecting to the network.
This line might be your problem:
