Hello, I’m having some problems with my hotspot setup. I’m using a routerboard 1100 ahx2 with v6.46.1 I have the hotspot all working and connected to my wireless router, now when I connect onto the wifi, I don’t get any Login screen prompt, in order to login I have to manually put the IP address or DNS name.
I used to have this same router setup where upon connecting it would automatically present the login screen (as long as there was an internet connection) I just cant seem to get it to work at all and have run out of ideas. it will redirect to login screen if I visit a http site (not that there is many left) Is there a way to activate the captive portal that loads automatically? Aldo for https redirects is the only way to sign ssl cert, as im sure my previous setup done this bu from what Ive read it seems like certs and everything are required and I definitely didn’t do this before.
The router was corrupted during an upgrade and backup config lost this is why I have these problems
Brendan
