post your configuration
I have the same problem.
Is this problem because we need this configuration
add chain=hotspot protocol=tcp dst-port=80 hotspot=local-dst action=redirect to-ports=64873
Why redirect command doesn’t exist as action?
Thanks in advance.
Levis
hotspot-login page doesn’t work if you have no dns available. the redirect does not work. simply add a dns-server to your mt (do not set up one yourself, just put in an ip of one) and it should work.
