the current formula of the cookie is to store a Mac value and compare it to every host in the hotspot if true then user is loged-in
A string of harvested Dhcp data :
Uhmmm… If you don’t like it, just don’t use it… And Mikrotik has request for feature section…
The “use it or leave it” argument is the poorest reply for an algorithm design analysis
this problem renders the hotspot package useless if not resolved
It’s not useless. It’s just not as secure as it could be. This is not solely a MikroTik problem, this has existed a while with other hardware.
Yes, there are methods to fix it. If you paid $10,000 for that router instead of $50, you’d have a legit gripe. Otherwise, wait.
its not a hardware problem !! its a software layer issue which can exist in mikrotik 3000$ routers
this post is getting way off point !!
