Hotspot Mikrotik Customization
I like to make a hotspot with a mikrotik Hlite. Simple once logged into the SSID it takes you to a landing page you accept terms and conditions and you have free internet for 30 minutes than after 30 minutes you cant log in for 12 hours. Also i would like to restrict the hotspot to only work from 10AM to 9PM
The Hotspot Trial user is perfect for what you want. You can edit the default login.html to remove the login box and use the trial user link as the “click here” to agree.
https://wiki.mikrotik.com/wiki/Manual:Hotspot_Introduction
https://wiki.mikrotik.com/wiki/Manual:IP/Hotspot
https://wiki.mikrotik.com/wiki/Manual:Customizing_Hotspot
Use the Scheduler to enable/disable your wireless interface to control the times it is available.
https://wiki.mikrotik.com/wiki/Manual:System/Scheduler
http://forum.mikrotik.com/t/create-schedule-for-wifi/29291/1
Hi, I just recently tried out the solution from mikrotikhotspot.io and it was super helpful. I use hotspot with a trial and had some custom data fields I wanted to capture.
