I perform integrate between hotspot and windows server radius (NPS) for authentication…the integration was succeed and users can access internet using their domain accounts.
To control the user usage of internet i add attributes in NPS to control download/upload limits :
Mikrotik-Recv-Limit
Mikrotik-Xmit-Limit
the limitation is applied successfully and when usage reaches the limit internet stops;;;; BUT when it login again with the same credentials it login successfully and resets download/upload counters again.
No quota reaches message appears.
How i can overcome the usage reset problem ???
I really need help here. Could you please provide information on how you did the hotspot authenticates from windows NPS?
Thanks,
