Hotspot Multi WAN - high cpu usage
Hi there,
I have a working multi-wan hotspot setup but I’m finding that the CPU usage is nearly always reaching 100% with just 5 users when running anywhere close to 100Mbps+ on at least 1 of the 3 WANS.
This is running on a RB1100AHx2 board!
I’ve tried contacting support but had no answer regarding this issue.
I would like someone’s help to find out a better method of running Multi-wan hotspot. Whereby the important issue is load balancing per user base (i.e. equal users on each wan and there login is bound to that WAN until they logout) with auto failover.
