Hotspot Nat
Hello all,
My question is
"How can I make Mikrotik to work in hotspot mode without NAT’ting connections please I want to know cause I have my own NAT server I would like to use it .
Regards,
Ammar
If u have NAT server, why just u configure it to your server (the hotspot), or is better that u just NAT your hotspot in ur mikrotik :laughing: , just a few step then finish, is easy to use
Just don’t add the masq NAT rule or remove any existing one. The Hotspot functionality will still work just fine and an upstream router will need to do the NAT. The Hotspot server does not need masq NAT.
Thanks JJCinAZ for ur he;p and thx ferry too.
Regards,
