Hotspot network stops responding
Currently running MT version 2.9.10 and have a problem in that the hotspot network stops responding to a ping for a short period of time. I thought it could have been one of the Access points but when I’m getting no response I ping the access point just before the router and get replies but when i ping the router at 10.5.50.1 I get no replies for up to a minute and then start getting replies again. At first I thought the router was rebooting but when I check the log there is no indication of a problem. I have replaced the hotspot network card, changed the ethernet connectors to the switch but has not solved the problem. Is there aything in the logging I can turn on to find out what is happening? It seems that if I reboot the router the problem will go away for a while but then starts up again.
