Hotspot not redirecting to login page
Its working fine on ROS 6.48.6 after upgrading to ROS 7.8 it stop working.
If I manually type routers IP it will bring me to login page.
I already email the support but no reply since 02/Apr/23 SUP-112422
Updated to 7.9.2 still not redirecting… :frowning:
Normally when that happen check for the DNS setting you setup for the hotspot, without proper dns settings it won’t work just my 0.2$
http://forum.mikrotik.com/t/hotspot/142439/1
Set arp=local-proxy-arp in interface section and add-arp=yes in DHCP section solved the problem.
is this normal to set?
Normal settings are arp=enabled and add-arp not set. Anything else is set for some particular reason, some “cooking recipes” advise to set arp=reply-only and add-arp=yes to force clients to use DHCP server assigned IP addresses instead of anything else (e.g. manually set IP addresses) … or arp=proxy-arp to fix some “problem” with communication between clients in different L2 segments (and the reasons to do it are most of times the wrong ones).
Its not working again on 7.10.2…:frowning:
Have you resolved this issue??
I’m still facing the same problem on the latest ROS
Please help me
