hotspot not working until disbled and enabled
Hello all,
I have 3.2 OS running hotspot but when power goes down then get back my hotspot not respond with login page until I enabled and disabled via winbox.
This is the configuration:
[admin@MikroTik] /ip hotspot> print
Flags: X - disabled, I - invalid, S - HTTPS
NAME INTERFACE ADDRESS-POOL PROFILE IDLE-TIMEOUT
0 hotspot1 LAN dhcp_pool1 default 2m
[admin@MikroTik] /ip hotspot profile> print
Flags: * - default
0 * name=“default” hotspot-address=0.0.0.0 dns-name=“” html-directory=hotspot
rate-limit=“” http-proxy=192.168.3.1:8080 smtp-server=0.0.0.0
login-by=http-chap split-user-domain=no use-radius=no
1 name=“hsprof2” hotspot-address=192.168.2.1 dns-name=“” html-directory=hotspot [not used]
rate-limit=“” http-proxy=0.0.0.0:0 smtp-server=0.0.0.0 login-by=http-chap
Upgrade to a recent version. What you’re experiencing is not caused by a configuration error.
Hi Fewi,
Can you specify that version? Is it 3.3?
Thanks alot.
Agree with fewi.
Upgrade to 3.30 or any of new version.
Thanks bro’s
