Hotspot on a virtual AP
Hi all
I want to set up a Hotspot on a virtual AP to separate local trafic and guests trafic so:
Situation:
1- I have my interface wireless wlan1 as master interface (Network: 10.23.53.0/24).
2- i Created a virtual interface wlan2 (Network: 192.168.1.0/24)
3- i created an hotspot on this virtual interface (wlan2)
4- ip pool and masquerading are ok
5- default-authentication=no on the wlan1.
6- Access-list on wlan1.
result:
  • I can see the new ssid (the virtual one)
  • clients can connect to this virtual AP and get addresses (in the network 192.168.1.0/24)
Problem:
  • when a client want to connect to internet, they can not get the page where they can authenticat.
  • So Clients can not connect to internet
solution:
PS: my gateway to internet is on the network (10.23.53.0/24) and the ethernet port connected to the gateway is in the same bridge as the master wireless interface (wlan1).
Thx
Do you have HotSpot on wlan1 interface ? Is it working fine ?
Make sure you have address DNS server address to ‘ip dns’ menu, at least one HotSpot user configuration,
check that HotSpot does not have state invalid.
No my Hotspot is on wlan2 (the virtual interface) and it’s running
It’s Ok now the problem was in the methode of authentication.
Sir, i cannot see ssid of new one virtual AP(no wep)
on the real one AP i have already customers with mac auth. and 104 wep key
tell me it is possible specific routerboard support that option virtual AP or not?
Hy.
I have the same problem with RB532 + Senao NL2511 Plus.
I have replaced that card with a SR2 (and an XR2 later), and voilà! the virtual ssid appears (with a public hotspot on it).
There’s no need of a special routerboard version, only a compatible (new) mPCI card.
make sure from MT have valid ip DNS where can resolve any domains on the world
why we have to make a virtual AP and a hotspot server on this virtual AP ?
whays yhe advantages of making virtual AP and virtual wlan if we making the hotspot on these virtuals ?
