We are looking at a way to add static routes for each hotspot user that logs in to the system.
Teting on MT Ver. 5.25+ / 6.4
By default the user gets a private ip address assigned by the DHCP (running on MT).
Once the user authenticates a new static route is added from the public ip pool as defined in the
hotspot user profile.
The current script which works about 90% of the time is as follows:
hotspot on-login script
[/ip hotspot host remove [find DHCP=yes]]
:local who $user;
:local macaddr [/ip hotspot active get [find user=$who] mac-address];
:local fromaddr [/ip hotspot host get [find mac-address=$macaddr] address];
:local toaddr [/ip hotspot host get [find mac-address=$macaddr] to-address];
:log info (“IP :”.$fromaddr." - TO-IP “.$macaddr.” To Addr ".$toaddr);
[/ip route add distance=2 dst-address=$address gateway=$fromaddr comment=$who]
hotspot on-logout script
:local who $user;
[/ip route remove [find comment=$who] ]
The problem that we face is if we need to give some users “Shared User” / “Simultaneous use” access,
multiple logins from the same userid.
First login of the userid works but the second login, logs - in to the system but wont get the route installed or
will just not work.
Any help would be appreciated.
regards
RB
