HotSpot on MT route os 3.rc4 with D-Link 2100AP
I instaling Hotspot & want that client’s conect to HS using D-Link 2100AP like AP-client.
On computer set get ip address auto. Clients get ip from HS DHCP server. When client type in brovser some address has redirect to login page. Login & see the error: internal error: login failed: ippool acquire failed. If the client use usb palnet all is ok.
I have install 5 hotspot but client use notebook or pocket PC, I never see such error. Please maybe any one have some problem.
Help
Hi, I have the same problem with OsBridge24 and other equipment. I solved the problem whith reload 2.9.44 OS rel.
I looking for help about because is a big problem.
Ciao
Thanks, but want that work in MT 3
Подозреваю что это проблема DWL-2100. В режиме клиента она прячет под свой MAC адрес все что за ней. Это можно убрать параметром matstate.
Some broblem, even change matstate value no make work dwl2100ap.
:confused:
What value you enter?
0,1,2,3 — перепробивал
