Hotspot on RB750
Hello Forum,
i had setup a hotspot on RB750; but i have some difficulties.
Explain:
i delete initial configuration and configure like that:
  • ETH1 is WAN interface and ETH2 is LAN. other interface are disabled
    i set hotspot normally like explanations in WIKI. It’s working **but when user connect and try to open some webpage, it isn’t automatically redirect to Captive Portal, so he need to type manually address of router or Domain Name to see Captive portal and authenticate.**After it, he can surf normaly.
    Can you tell me what i can do to redirect automatically users when they try to surf.
from your explanation, is it on ETH2 you enabled hotspot?
try to make new config with mac-winbox, than do "hotspot setup" and put on local[lan] interface, and be careful after setup finish all interface will unrechable behin hotspot until they are correct to login via login page.
regards, :wink:
Hasbullah.com
