hein86
May 14, 2025, 12:21pm
1
Good day everyone
I’m busy with a setup of 18 Access Points where we need to limit users access the Wireless networks through a username and password. I’ll dot down the main config I have down below:
Ether2 → PPPoE for internet access
Ether3 → Switch connecting the office LAN connections (PC’s, printers in the office, etc)
Ether4 → Switch connecting Access Points and multiple other switches to provide uplink for Access Points.
On the Access Point Controller we specify the network to use VLAN ID: 30
We can connect successfully to the network but we cannot get an IP address from the DHCP Server. I have tried adding a static IP but also cannot ping 192.168.30.1.
I have exported most config below.
add name="bridge15 - LAN"
add name=bridge16-Wifi_LAN
set [ find default-name=ether3 ] name=ether3-LAN15
set [ find default-name=ether4 ] name=ether4-LAN16
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether2 name=pppoe-out1 password=xxxxxx \
use-peer-dns=yes user=xxxxxx
/interface vlan
add interface=bridge16-Wifi_LAN name=vlan30 vlan-id=30
add name=dhcp_pool-LAN ranges=192.168.15.20-192.168.15.200
add name=dhcp_pool-WIFI ranges=192.168.16.30-192.168.16.210
add name=dhcp_pool-Hotspot ranges=192.168.30.20-192.168.30.50
add address-pool=dhcp_pool-LAN disabled=no interface="bridge15 - LAN" lease-time=8h name=dhcp1
add address-pool=dhcp_pool-WIFI disabled=no interface=bridge16-Wifi_LAN lease-time=4h name=dhcp2
add address-pool=dhcp_pool-Hotspot disabled=no interface=vlan30 name=dhcp3
add bridge="bridge15 - LAN" interface=ether3-LAN15
add bridge=bridge16-Wifi_LAN interface=ether4-LAN16
add address=192.168.15.1/24 comment=Sontus-LAN interface=ether3-LAN15 network=192.168.15.0
add address=192.168.16.1/24 comment=SonitusPersoneel-Wifi interface=bridge16-Wifi_LAN network=\
192.168.16.0
add address=192.168.30.1/24 interface=vlan30 network=192.168.30.0
add address=192.168.15.0/24 comment=Sonitus-LAN dns-server=192.168.15.1 gateway=192.168.15.1
add address=192.168.16.0/24 dns-server=192.168.16.1 gateway=192.168.16.1
add address=192.168.30.0/24 gateway=192.168.30.1
set allow-remote-requests=yes servers=1.1.1.1,9.9.9.9
add action=accept chain=input comment="Accept established connections" connection-state=\
established
add action=accept chain=input comment="Accept related connections" connection-state=related
add action=reject chain=input connection-state=new in-interface=ether1 port=53 protocol=udp \
reject-with=icmp-network-unreachable
add action=reject chain=input connection-state=new in-interface=ether1 port=53 protocol=tcp \
add action=drop chain=input comment="Drop invalid connections" connection-state=invalid
add action=accept chain=input comment=UDP protocol=udp
add action=accept chain=input comment="Allow limited pings" limit=50/5s,2:packet protocol=icmp
add action=drop chain=input comment="Drop excess pings" protocol=icmp
add action=log chain=input comment="Log everything else" log-prefix="DROP INPUT"
add action=drop chain=input comment="Drop everything else" disabled=yes
add action=drop chain=input dst-port=53 in-interface=ether1 protocol=tcp
add action=drop chain=input dst-port=53 in-interface=ether1 protocol=udp
add action=drop chain=forward comment="Block Cross Interface 15 to 16" in-interface=\
"bridge15 - LAN" out-interface=bridge16-Wifi_LAN
add action=drop chain=forward comment="Block Cross Interface 16 to 15" in-interface=\
bridge16-Wifi_LAN out-interface="bridge15 - LAN"
Anyone have any idea how I can troubleshoot this?
anav
May 14, 2025, 12:44pm
2
Would need to see the complete config
/export file=anynameyouwish ( minus router serial number, any public WANIP information, keys )
hein86
May 15, 2025, 12:18pm
3
Hi Anav
We experienced a power outage but I managed to get the file out. Please see below:
# may/15/2025 14:08:40 by RouterOS 6.49.17
# software id = X4F7-LWBJ
# model = RB760iGS
add add-default-route=yes disabled=no interface=ether2 name=pppoe-out1 \
password=xxxxx use-peer-dns=yes user=xxxxx
/interface vlan
add name=dhcp_pool4 ranges=192.168.30.20-192.168.30.50
add address-pool=dhcp_pool-LAN disabled=no interface="bridge15 - LAN" \
add address-pool=dhcp_pool-WIFI disabled=no interface=bridge16-Wifi_LAN \
add address-pool=dhcp_pool4 disabled=no interface=vlan30 name=dhcp3
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
sword,web,sniff,sensitive,api,romon,dude,tikapp"
/interface pptp-server server
set enabled=yes
add address=192.168.15.1/24 comment=Sontus-LAN interface=ether3-LAN15 \
add address=192.168.16.1/24 comment=SonitusPersoneel-Wifi interface=\
bridge16-Wifi_LAN network=192.168.16.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=3m
/ip dhcp-server lease
add address=192.168.16.32 client-id=1:9c:c9:eb:e6:fd:58 mac-address=\
9C:C9:EB:E6:FD:58 server=dhcp2
add address=192.168.15.0/24 comment=Office-LAN dns-server=192.168.15.1 \
add action=accept chain=input comment="Accept remote winb" dst-port=8291 \
protocol=tcp
add action=accept chain=input comment="Accept established connections" \
connection-state=established
add action=accept chain=input comment="Accept related connections" \
add action=reject chain=input connection-state=new in-interface=ether1 port=\
53 protocol=udp reject-with=icmp-network-unreachable
53 protocol=tcp reject-with=icmp-network-unreachable
add action=drop chain=input comment="Drop invalid connections" \
add action=accept chain=input comment="Allow limited pings" limit=\
add action=log chain=input comment="Log everything else" log-prefix=\
"DROP INPUT"
add action=drop chain=forward comment="Block Cross Interface 15 to 16" \
in-interface="bridge15 - LAN" out-interface=bridge16-Wifi_LAN
add action=drop chain=forward comment="Block Cross Interface 16 to 15" \
in-interface=bridge16-Wifi_LAN out-interface="bridge15 - LAN"
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox port=8291
set api-ssl disabled=yes
/ip ssh
set forwarding-enabled=remote
/system clock
set time-zone-name=Africa/Johannesburg
/system identity
set name=Hotspot-Mikrotik
Do you need the .rsc file as well?
All access points have a static IP on their LAN ports between 192.168.16.11 and 192.168.16.29.
anav
May 29, 2025, 2:46pm
4
I would start by using vlans for all subnets.
Not clear why you have two bridges either.
Why do you have pptp server enabled, is that required for hotspot??
You seem to have changed firewall rules from default…for what purposes??
I dont see any IP HOTSPOT settings ???
