Which applications are you using to create the hotspot login (and the rest) page?
Dreamweaver? Frontpage? Other tools?
MT supports html / php / asp ? Any idea where to get some info?
Thank you
Thank you
handwritten html + validator.w3.org is the only way to go. all best sites are made like that.
php and asp is not supported. only basic html
