Hotspot ping problem
I have router board 750GL with OS 6.7 on it.
I have default configuration with Hotspot service. It’s working in Work Group environment (Not Domain). All my clients and server are in the same net ID. When i enable the hotspot everything is fine for about 2 hours and after that it will disconnect me from my server (Windows 2003 R2 with Static IP). I check it with Ping command. Exactly after that time the ping will get “Time request time out” and after about 15-20 retry the ping will be back.
But during this time my accounting software get disconnected form its database server and error message will pops up. I tried Walled Garden IP list but nothing changed.
I upload Ping result for more detail. ( in the text file do search for “Connection Lost” and you will see the problem
Please help me to find out where is the problem come from and what is the solution is!!!
Thank every one in advance.
Ping_server_result.txt (1.53 KB)
