Hotspot Portal unpredictable captive portal popup after session expires
HEX Lite, I’ve managed to set up the hotspot and it correctly pops up on an Android device and allows me to connect. However, when the session expires, the captive portal Android popup is very unpredictable as to when it will pop up. Sometimes it is immediately, sometimes 90s, sometimes never. Is this a config issue or just an Android quirk?
By all means correct me if any of my config is incorrect, especially any of the timeouts.
Thanks in advance!
Config Export:
add admin-mac=CC:2D:E0:74:C9:45 auto-mac=no comment=“created from master port”
name=bridge1 protocol-mode=none
set [ find default-name=ether1 ] advertise=
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether2 ] advertise=
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=
ether2-master
set [ find default-name=ether3 ] advertise=
set [ find default-name=ether4 ] advertise=
set [ find default-name=ether5 ] advertise=
add comment=defconf name=WAN
add comment=defconf name=LAN
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
/ip hotspot profile
set [ find default=yes ] html-directory=flash/hotspot login-by=
http-chap,http-pap
add dns-name=.local hotspot-address=192.168.88.1 html-directory=
flash/hotspot login-by=http-chap name=hsprof1
/ip hotspot user profile
set [ find default=yes ] add-mac-cookie=no shared-users=unlimited
add add-mac-cookie=no !mac-cookie-timeout name=Guest open-status-page=
http-login session-timeout=5m shared-users=unlimited transparent-proxy=yes
add address-pool=default-dhcp disabled=no interface=bridge1 name=defconf
/ip hotspot
add address-pool=default-dhcp disabled=no idle-timeout=none interface=bridge1
name=hotspot1 profile=hsprof1
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/user group
set full policy=“local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,passw
ord,web,sniff,sensitive,api,romon,dude,tikapp”
add bridge=bridge1 interface=ether2-master
set discover-interface-list=discover
add comment=defconf interface=bridge1 list=LAN
add interface=bridge1 list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=bridge1 list=mactel
add interface=bridge1 list=mac-winbox
add address=192.168.88.1/24 comment=defconf interface=bridge1 network=
192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=
192.168.88.1
set allow-remote-requests=yes servers=192.168.88.1,8.8.8.8
/ip dns static
add address=192.168.88.1 name=router.lan type=A
/ip firewall address-list
add address=
********* list=“"
add action=passthrough chain=unused-hs-chain comment=“place hotspot rules here”
disabled=yes
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
in-interface-list=LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=
invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
connection-state=new disabled=yes in-interface-list=WAN
disabled=yes
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=
out,none out-interface-list=WAN
add action=masquerade chain=srcnat comment=“masquerade hotspot network”
src-address=192.168.88.0/24
/ip hotspot service-port
set ftp disabled=yes
/ip hotspot user
add name=notsosecretuser password=notsosecretpass profile=Guest server=hotspot1
/ip hotspot walled-garden ip
add action=accept disabled=yes !dst-address dst-address-list="
!dst-port !protocol server=hotspot1 !src-address !src-address-list
/ip service
set www-ssl certificate=“Hotspot Server”
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
